Results 1 to 2 of 2
    176
    Most Efficient Solution to Extract Calendar from OST File
    If you’ve lost access to your Outlook account but still have the OST file, the calendar inside it may contain important office meetings, personal appointments, or reminders that you can’t risk losing. So, the best approach is to extract calendar from OST file safely. Manual solutions help only when Outlook is functional, but if not, the MailConverterTools OST to PST Converter Tool becomes the perfect alternative. It opens the OST file directly, shows all mailbox folders, and lets you convert only the calendar items into ICS format. With filters and preview options, it ensures a smooth and error-free extraction process. Apart from this, the software offers several advanced filtering options. Users can remove duplicate items, convert or back up emails without attachments, split the resulting PST file, and even set a custom name for the output folder. This makes the conversion process more flexible and efficient.
    118
    If you are looking for a reliable and efficient way to extract attachments from OST files, for completing this task you can take the help of an advanced application like Softaken OST to ICS Converter Software. This professional application allows you to extract calendars from OST files while keeping the original data structure and formatting intact. It supports both oversized and small OST files, ensuring you can extract calendars from any size of OST files. Before extracting calendars, you can review data with its preview feature. This application is designed with an easy-to-use interface that makes it easy for you. Moreover, the professional software works on all versions of Windows OS without any errors.
