Results 1 to 5 of 5
    Jul 2025
    103
    Remove Duplicate Attachments from Outlook Email
    Dealing with duplicate attachments in Outlook can be frustrating, as they quickly clutter your mailbox, consume storage, and slow down performance. The most effective way to handle this issue is by using the Cigati Outlook Duplicate Remover. This robust tool scans your entire Outlook account, including emails, attachments, contacts, calendars, and more, to accurately detect and remove duplicate items while keeping your original data safe. With advanced filtering options, you can customize the cleanup process by sender, date, subject, or attachment type, ensuring precise and controlled results.
    For those who want to understand the process in detail, the Cigati Solutions blog “How to Delete Duplicate Attachments from Outlook” provides a step-by-step guide. It explains why duplicates occur, outlines manual removal methods, and highlights the advantages of using an automated tool. Combining the power of the Cigati Outlook Duplicate Remover with the insights from the blog allows users to clean their mailboxes efficiently, save storage space, and maintain optimal Outlook performance. This method is ideal for anyone looking to organize their mailbox quickly, reduce clutter, and enjoy a smoother, more efficient email experience.
    281
    The best PST Duplicate Remover Tool is a highly dependable and user-friendly tool that ensures seamless deletion of multiple Outlook duplicate files such as emails, contacts, calendars, and other items without Outlook. It offers a straightforward and interactive graphical user interface, making it suitable for both technical experts and non-technical users. The utility is compatible with all Windows operating systems and versions of MS Outlook, ensuring wide accessibility and versatility. It grants swift and 100% assured deletion without change in data quality. Without any trouble, complete data is deleted by this application.
    36
    You can remove duplicate attachments from Outlook email then I can suggest the best option for this. You can use GainTools Outlook Duplicate Remover, which automatically scans Outlook files like email, contacts, notes, tasks, calendar, events, attachments, etc, finds duplicate items and removes them without losing the original data and saves time, effort, and keeps a clean mailbox. The software handles a large number of duplicate Outlook emails without downloading any other application. It has an easy interface for non-technical users, and they can operate it without any technical knowledge. The tool runs on all Windows OS versions, like 11, 10, 8.1, 8, and 7. The tool provides a free trial before purchasing it, and after removing duplicate Outlook emails, it will give a preview of the results.
    Visit here: https://www.gaintools.com/pst/duplicate/
    Oct 2025
    30
    I recently faced the same issue with duplicate attachments in Outlook, especially after PST imports and mailbox synchronization. Manually finding duplicate attachments is difficult and time-consuming because Outlook does not provide a direct option to remove them across an entire mailbox. A simpler approach is using SysTools Outlook Duplicate Items Remover, which can scan PST files and identify duplicate emails containing identical attachments based on parameters like Subject, Date, Sender, and Attachments. It supports bulk processing, preserves folder structure, and removes duplicates safely without affecting original data. You can refer to this blog remove duplicate attachments in Outlook.
    May 2022
    160
    Duplicate attachments pile up when the same file is sent across reply chains, forwarded repeatedly, or imported more than once. They bloat mailbox size, even when the emails themselves look different.
    Manually removing them means opening each message, which isn’t practical at scale. A better approach is to scan the PST file with a tool that compares emails and their attachments. Shoviv Outlook Duplicate Remover includes attachments among its matching criteria, so you can identify repeated items, review the flagged results, and delete them or move them to a separate folder.
    Before running any cleanup, back up your PST file, and spot-check results to make sure no unique attachments were removed.
    Read more: https://www.shoviv.com/outlook-duplicate-remover.html
    A Email Migration Consultant at Shoviv Software
