Results 1 to 8 of 8
    Oct 2006
    970
    Looking for a right VPS account
    Which VPS is better to sign up with - just.hosting and legionbox.com?
    What would you do if you were me?
    Feb 2009
    1,611
    Can recommend you try to compare rates, features, compatibility, performance, and reliability.
    Check out these reliable VPS options:
    1) GTHost.com
    2) Hostingsource.com
    3) Hostinger.com
    What is so important is you always experience you are not alone dealing with customer or tech support.
    Jun 2025
    130
    Between just.hosting and Legionbox, both fall into the ultra‑budget VPS category with mixed reliability. If I were in your position, I wouldn’t choose either for anything important.
    A few stronger, safer alternatives:
    InterServer- stable, long‑running, and offers a price‑lock guarantee
    Vultr -solid performance and simple management
    Linode reliable uptime and good support
    DigitalOcean -beginner‑friendly with great documentation
    67
    I’ve had a solid experience using hostpro.com VPS — consistent speed, predictable resource usage, and support that actually helps when issues come up.
    Sep 2006
    952
    Have a look at VPS deals from hostingsource.com (VPS First Month discounts starting at $3- Coupon Code: $3VPSM1ALL) and inet.ws as they are proven to be the best in delivering quality hosting services.
    I really like their low prices, fast approach towards everything, bandwidth and uptime, control panel and last but not least their customer service protocol.
    Oct 2021
    101
    Quote Originally Posted by klimm View Post
    That low entry price is perfect for running benchmarks. I always advise spinning up a cheap instance like that for a few days just to run I/O tests and check network latency from your target location before moving any production sites over.
    Registered User NimbusRise's Avatar
    Aug 2024
    35
    On hostpro.com VPS services, KVM ensures hardware-level virtualization with independent kernel instances. NVMe storage improves responsiveness under load. Backup cycles run daily with extended retention. Data centers in different regions support geographically distributed deployments. Administrative flexibility is maintained through multiple supported control panels.
    95
    For a VPS that needs to deliver real performance, hostpro.com stands out compared to many budget providers. Their infrastructure uses SSD/NVMe drives, which speeds up disk-heavy operations, and the network routing stays stable under sustained loads. Full root access gives you control, and the semi-managed options are helpful if you want less sysadmin overhead. Uptime has been consistently high from my tests and reports, and support actually helps with tuning and troubleshooting.
