Results 1 to 5 of 5
    Mar 2025
    Noida
    116
    Post How to Convert EML to PST File?
    When Outlook doesn’t open EML messages directly, it can be frustrating trying to manage your email archives. The ConverterTools EML File Converter offers a smooth solution by letting you change your EML files into a format that Outlook understands. It lets you convert EML to PST File while keeping all important information intact. The tool keeps the folder structure exactly as it was, so your inbox, sent items, and other folders stay organized. Another helpful feature is that you can preview EML files before converting them, giving you confidence that only the right messages will be included in the final Outlook file. The interface is simple enough for anyone to use.
    Nov 2024
    34
    Looks like you are still searching for a simple way to convert EML to PST file? If this is so then I recommend you to try BitData Migration EML Converter. The software move bulk of EML data to Outlook in just one go along with attachments files. EML Files to PST Converter is best tool for saving EML files with intact mail properties and folder hierarchy. To know more information about the tool, try demo edition of EML to PST Converter.
    53
    CubexSoft EML Converter is a reliable email conversion tool that allows users to convert EML files into multiple formats such as PST, PDF, MSG, MBOX, HTML, and more. It supports batch conversion, preserves attachments and email formatting, and maintains the original folder structure, making it ideal for email migration, backup, and archiving. The whole process is very easy with its easy and intuitive GUI. Users can also try the free demo and export up to 25 files from the selected folder for free.
    141
    I easily convert EML file to PST format using EmailsGuru EML to PST Converter. It is specifically developed to convert EML files to PST format including emails, contacts, calendars, notes, tasks and all others items. It is completely professional way to import emails from EML to Outlook PST format. This tool kept intact all data integrity and email formatting throughout the migration process. It is capable to convert EML files of 30+ email clients like Windows Live Mail, Outlook Express, Mozilla Thunderbird and many others. Users can smoothly install and run this utility on Windows 11, 10, 8.1, 8, 7, XP, Vista and all below versions.
    Mar 2025
    72
    Converting a few EML files is fairly straightforward, but the process becomes much less convenient when the files are spread across folders or contain important attachments and message details. That is usually where a proper EML to PST conversion makes more sense.
    If the goal is to move EML data into Outlook, one practical approach is to create a PST from the EML files and then open that PST in Outlook. Softaken EML to PST Converter can be used for this purpose when there are many files to handle. It supports EML and EMLX, allows single files, multiple files or entire folders to be selected and provides a preview before creating the PST.
    To convert the EML files into PST, you can follow this simple process:
    1. Select the EML files or the folder containing them.
    2. Scan and preview the messages.
    3. Check important headers, attachments, and folder structure.
    4. Export the selected data into a new PST or an existing PST.
    5. Open the resulting PST in Outlook.
    The useful part here is that the software page specifically mentions retaining folder hierarchy, attachments, SMTP headers, dates, HTML formatting and inline images during the conversion.
    For only a handful of EML files, a manual method may be sufficient. When migrating a large mailbox, it is generally easier to manage and verify the process by first creating a PST.
