Results 1 to 15 of 15
    May 2008
    1,682
    VPS or Shared Hosting for a New Forum?
    Hi, I’m about to launch a new discussion forum and need hosting advice.
    Should I start with shared hosting or go straight to a VPS? How much RAM and bandwidth would a small but growing forum require?
    Any reviews on Hostnamaste.com hosting services? I’d love advice from experienced forum owners.
    Dec 2019
    772
    Ready to scale? Get enterprise-level power with bodHOST Managed Windows VPS Hosting for just $14.99/month. Claim our current Best Offer: 15% OFF to give your applications the speed they need. Grow with confidence on our reliable Windows VPS Hosting and secure your discount today!
    Dec 2025
    37
    I started my first forum on shared hosting and upgraded later when traffic grew. In the beginning it’s usually enough unless you expect hundreds of users online at the same time. I personally used hostpro.com for a few small projects and had a good experience with their support – they respond pretty fast when something breaks. Their VPS plans are also reasonably priced if you need to scale later. So starting shared and upgrading later can work well.
    Aug 2010
    74
    Shared hosting is ok to start but once you grow it will need a VPS for the traffic.
    Forums are very traffic intensive.
    oXnames - Simple Domain registration, Hosting & VPS
    Jun 2025
    269
    For a brand new forum, shared hosting is usually fine to start with since traffic will be low in the beginning. Once the community grows, moving to a small VPS gives you more control and better performance; something like 1–2 GB RAM is a common starting point.
    You could also look at InterServer’s VPS single-slice plan, it’s pretty cheap and flexible (1 CPU, 2 GB RAM, 40 GB SSD or 1 TB HDD, 2 TB bandwidth on a 10 Gbps port for about $2.40/mo with coupon JV-20-LIFE). The nice part is you can scale it up to more slices later if the forum grows. https://interserver.net/vps/
    156
    Having spent considerable time evaluating different VPS setups for my websites and applications, hostpro.com has consistently provided strong performance and reliability in my own usage. The servers deliver quick response times even during peak loads without unexpected hiccups. They generate daily backups across all services, which makes it simple to recover data following any corruption, unsuccessful updates, or unauthorized access. Their support staff operates 24/7, bringing solid expertise to every inquiry at no additional cost.
    Oct 2021
    168
    Quote Originally Posted by Sofia_Bila887 View Post
    Should I start with shared hosting https://eldfall-chronicles.com/sl/co...ame-miniatures or go straight to a VPS? private label cbd manufacturers How much RAM and bandwidth would a small but growing forum require?
    I agree with the others that starting small is usually the safest bet for your budget. If you choose a provider that allows one-click upgrades, you can easily scale from shared to a VPS once your active user count starts to climb. Just make sure to keep your database optimized from day one to ensure fast loading times as you grow.
    Jul 2008
    1,703
    Why not give HostPresto cheap hosting a try?
    The hosting service earns appreciation for its seamless scalability, making it easy for me to upgrade resources without interruptions. Get 20 months of hosting, for the price of 10. Buy any new annual Web, Premium, Reseller, Email or Cloud Server hosting package and pay for just 10 months. Use code 20YEARS at checkout. Try for £1.00 - they are offering 1 month trial now.
    Do you want to gamble? Here is ==>> ONLINE POKER
    Jun 2026
    16
    I'd start with Shared Hosting. It's budget-friendly, includes a control panel, and is more than enough for a new forum. You can always upgrade to a VPS later as your community grows. VPS hosting costs more and usually doesn't include a control panel by default.
    Jul 2026
    25
    Keep in mind that slow loading pages and downtime are a surefire way to lose your visitors, so take your time to choose stable and reliable host.
    AYKsolutions.com - High Bandwidth Specialists - 10Gbps/20Gbps+ Unmetered & DDOS Protected.
    Over 20+ Global Locations - Asia (Hong Kong, Singapore, Tokyo), Mexico, Brazil, India, Australia, US, CA, EU - Bare Metal and Virtual Cloud. All Managed.
    We are Professional. Painless. Polite.
    Mar 2009
    1,686
    SSL, backups, and security features included — I feel completely safe. Hostnamaste.com Server Locations: USA, France, Canada, India, Russia.
    The fast SSD storage has significantly improved my site’s loading speed. Their intuitive and well-organized dashboard makes managing hosting effortless.
    Jul 2026
    12
    I’d start with shared hosting if the forum is genuinely new and traffic is still low. It keeps costs and server management simple while you validate the community.
    The main thing I’d watch is resource usage rather than trying to predict an exact RAM requirement. Forum software, database queries, plugins, attachments, caching, and bots can affect resource consumption quite a bit.
    Once you’re seeing sustained CPU/RAM limits, slower database queries, or regular traffic spikes, that’s a good point to consider moving to a VPS. A VPS also makes sense earlier if you need more control over the server environment.
    For a small forum, I’d prioritize reliable backups, good caching, security updates, and database optimization before paying for significantly more server capacity. The ability to scale or migrate easily is also worth considering when choosing the initial host.
    Jan 2020
    269
    I’d go with a small VPS over shared hosting if your budget allows. A plan with 2 vCPUs, 4 GB RAM, and NVMe storage is a great starting point for a growing forum. I can’t comment on Hostnamaste from personal experience, but I’ve had a good experience with Fresh Roasted Hosting. Their VPS plans are reliable, fast, and easy to upgrade as your community grows.
    Nov 2026
    I'd start with shared hosting for a small forum, then move to a VPS as traffic grows. If you choose a VPS, InterServer is worth comparing for affordability.
    Nov 2026
    4
    yeah, shared hosting makes sense for a new forum tbh. no point paying extra for a VPS until traffic picks up lol. i'd focus on uptime, backups and support first, then upgrade when needed
