Results 1 to 6 of 6
    Mar 2007
    969
    Which one is better to sign up with?
    Which one (inet.ws or planethoster.com) is better to sign up with?
    I intend to host a blog. Any ideas?
    Mar 2009
    1,637
    Before recommending anything, it would help to know your target audience location, budget range, and whether you need managed or unmanaged services.
    I am quite happy using hosting services provided by these hosts:
    1) Hostingsource.com
    2) Hostpresto.com
    3) Verpex.com
    The price is very reasonable compared to other hosts I've seen.
    Aug 2022
    429
    When it comes to the reliability of web hosting services, M2Host comes first. Our web hosting plans are affordable and reliable. Our plan starts at just $1 per month. It includes services like 24/7 customer support, choice of operating system, and more. For more information, please visit our website.
    Jun 2025
    173
    Between those two, I’d lean toward the one with more consistent uptime and support reviews, since that matters most for a blog. That said, you might also want to check out InterServer.it’s around $1/month with the same renewal price, includes SSL and email, and is pretty reliable for simple sites. It’s a nice budget-friendly option if you’re just starting out.
    https://my.interserver.net/buy_webho...?website=11517
    Jan 2020
    227
    If you’re planning to start a blog, both inet.ws and planethoster.com could work, but before choosing a host it helps to understand what actually matters. This blog has a really helpful WordPress guide that explains how to pick the right web host for a blog in simple terms. It’s a good read and can make the decision much easier.
    110
    From my own trial with several providers over the years, one name I keep coming back to is hostpro.com. Their system automatically creates daily backups of every service, which helped me restore a corrupted database after a failed security patch. I also appreciate their technical support—qualified people available 24/7, and they’ve solved my odd configuration issues for free.
