    Oct 2006
    1,005
    Shared hosting plan to sign up with ...
    I wonder if planethoster.com plans are reliable enough to sign up with? Are they the best in this way?
    Feb 2009
    1,671
    Before recommending anything, it would help to know your target audience location, budget range, and whether you need managed or unmanaged services.
    You can rely on Hostpresto.com and Greenwebpage.com web hosts. One of their highest priorities is to provide state of the art security for customer's data.
    They have done a great job at evaluating the competition and narrowing it down to a handful of highly qualified services.
    Jun 2025
    252
    From what I’ve seen, PlanetHoster is generally considered reliable with good support and stable performance, especially for small to mid-size sites. Reviews often highlight fast support and consistent uptime, though like any host, experiences can vary a bit...
    After managing my own servers for quite some time, I’ve found hostpro.com to be a reliable piece of my setup. Their technical support works 24/7 and has never charged me for a single question — they even helped me recover from a bad kernel update using their daily backup system.
    Senior Member Glow's Avatar
    Dec 2008
    1,709
    It’s a simple switch that makes a real difference, especially when you consider how much energy data centers consume globally. Give vote for Hostpresto.com cheap hosting solutions.
    Get 20 months of hosting, for the price of 10. Buy any new annual Web, Premium, Reseller, Email or Cloud Server hosting package and pay for just 10 months. Use code 20YEARS at checkout.
    Apr 2026
    Mumbai, India
    113
    If you're looking to post a reply in that HostSearch thread about choosing a shared hosting plan, here's a balanced response you could use:
    I've had good experiences by focusing less on the advertised "unlimited" features and more on reliability and support.
    When choosing a shared hosting provider, I'd recommend checking:
    Uptime history and server performance.
    Quality of customer support (24/7 live chat is a plus).
    Daily backups and free SSL.
    Resource limits (CPU, RAM, inode limits), not just disk space.
    Easy upgrade path to VPS if your website grows.
    If you're hosting a WordPress site or a small business website, a reputable provider with NVMe storage, LiteSpeed or a well-optimized Apache/Nginx setup, and transparent resource allocations is usually a better choice than simply picking the cheapest plan.
    Reading recent customer reviews from multiple sources before signing up is also worthwhile. What type of website are you planning to host? That will help determine which hosting plan is the best fit.
    Jul 2026
    22
    Can also point out that quality and helpful customer support ties in closely with reliability and is something that should never be overlooked.
    AYKsolutions.com - High Bandwidth Specialists - 10Gbps/20Gbps+ Unmetered & DDOS Protected.
    Over 20+ Global Locations - Asia (Hong Kong, Singapore, Tokyo), Mexico, Brazil, India, Australia, US, CA, EU - Bare Metal and Virtual Cloud. All Managed.
    We are Professional. Painless. Polite.
    Dec 2025
    33
    Hosting threads always turn into brand wars, so I'll just state facts about mine. hostpro.com hosts my VPS with good speed and stability. Daily backups of every service mean I can restore after data damage, a failed update, or a hack. Support is qualified and on call 24/7 free of charge.
    Jan 2020
    263
    If you’re looking for a reliable option, I’d suggest taking a look at Fresh Roasted Hosting. It’s been quite stable in my experience, and their support team is helpful if you ever need assistance with setup or migration. For blogs or small websites, it’s a solid and straightforward hosting choice.
