Results 1 to 4 of 4
    Apr 2025
    2880, Zanker Road. California, USA
    80
    Will my Outlook folders and attachments be preserved when importing PST to Gmail?
    Yes, but only if you skip the manual method. The standard approach involves enabling IMAP in Gmail, configuring Outlook to sync with your account, and then dragging emails across folders one at a time. Attachments often get dropped mid-sync, folder names don't always map correctly to Gmail labels, and the whole process stalls with larger PST files.
    If you are looking for guidance on how to import Outlook PST to Gmail without losing folder structure or attachments, the DRS Softech PST File Converter handles it properly. It preserves your original folder hierarchy and migrates every attachment intact — nothing gets left behind in the process. The tool supports bulk PST import, so you can move multiple files in a single run. A built-in preview lets you verify emails before migration, and a date filter helps you bring over only what you actually need. The interface is clean and beginner-friendly, so no technical knowledge is required to get through it.
    Here are the Steps to Import Outlook PST to Gmail:
    1. Download and install the DRS Softech PST File Converter on your Windows or Mac system.
    2. Click Select Files or Select Folder to load your PST files, then hit Next.
    3. Preview the emails, select what you want to migrate, and click Next.
    4. Choose Gmail Account as the saving format and sign in with your credentials.
    5. Apply date filters or advanced settings as needed, then click Convert.
    255
    Are you looking for a solution on how to import PST to Gmail account? if yes, then use a professional CubexSoft PST Converter Tool to export PST file to Gmail webmail account. The feature helps to get the desired conversion results each time. It retains the original properties of Outlook PST files. The advanced application supports entire data conversion. For getting more details about the tool, you can first utilize its free demo version, which allows you analyse its working by moving 25 emails from each PST file to desired format without cost. To migrate bulk emails from PST to any suitable format you need to buy its Licensed Edition.
    65
    If you have urgent requirement and want quick, perfect, safe & advanced data backup from PST to Gmail then you can try BitVare’s PST Converter for Mac & Windows that has option to directly save PST files into Gmail account. It has also preview options that helps to preview data without Outlook. Using it you can also save attachments on your system. Try it and know how to import PST file to Gmail without any cost.
    129
    By utilizing MacMister PST Converter for Mac & Windows, you may import PST files to Gmail without any worries. By using the app, you can leave all your stress behind as the tool will safely transfer the entire PST database to Gmail with 100% accuracy. The original data will not get affected. The GUI of the software is friendly and manageable. Anyone can implement the process and convert PST files with ease. And with Gmail, users can use the same tool to import PST files into 15+ other saving options. Also, the tool advanced features will help users importing PST files to Gmail according to the requirements. Download MacMister PST Converter for Mac & Windows freeware version and import 25 PST files for free.
