A "2ms latency measurement " means the network latency from your forex VPS to the destination server could be about two milliseconds under ideal conditions. That is very fast, but it does not mean your entire trade executes in 2 seconds.
[/SIZE]I have found DedicatedCore useful for running MT4, MT5, and automated strategies where stable connectivity is important. When evaluating the DedicatedCore setup, the actual route to your broker is more important than the advertised latency alone.
What 2ms Latency Really Means
- Fast network response: The transfer speed of data from one server to another is relatively fast.
- Broker location matters: Your brokers trading server itself may make an enormous difference in terms of latency
- Routing affects results: The fact that different routes may be used on the internet means that even two servers which are near one another may yield different latency figures.
- Stable latency matters: Consistent 23ms performance can be more useful than occasional 1ms readings with frequent spikes.
- Execution takes longer: Broker processing, liquidity, order matching, and platform response happen after the network request.
- Slippage can still occur: Low latency does not eliminate slippage during volatile markets or periods of limited liquidity.
- VPS resources matter: CPU, RAM, and storage can affect how smoothly multiple MT4/MT5 terminals and EAs operate.
- Test before trading: A real VPS-to-broker test can reveal latency, packet loss, and connection stability more accurately
When I checked DomainRacer for forex VPS. I found that testing the actual VPS-to-broker connection is important rather than relying only on the advertised latency: consider checking the latency actually on the VPS and your broker rather than simply considering the latency number itself. A DomainRacer Forex VPS with a suitable location and adequate resources can provide a practical environment forMT4, MT5, and automated trading.
Bottom line: 2ms is a low and consistent latency, reliable routing, suitable VPS resources, and a dependable broker
