Results 1 to 3 of 3
    Mar 2025
    Noida
    133
    How do I convert MBOX to PST while preserving the original folder structure?
    Many user to convert MBOX to PST while preserving the original folder structure, use a dedicated MBOX conversion tool that can directly access the MBOX files and maintain their mailbox organization. MacSonik MBOX Converter for Mac supports MBOX, MBX, and MBS files and can convert them directly into PST without requiring Outlook or another email client.
    The conversion process is straightforward. First, download and launch the MacSonik MBOX Converter. Add a single MBOX file or an entire folder containing multiple MBOX files. The software automatically detects supported mailbox data and lets you preview emails before conversion. Next, select PST as the export format and apply any required filters, such as date range, sender, subject, or mail status.
    To retain the original organization, select the appropriate mailbox or folder structure during the conversion and choose the destination location for the resulting PST file. Then start the conversion process. The tool is designed to handle bulk conversion and supports direct source access, making it suitable for large MBOX collections as well.
    After conversion, the generated PST can be opened or imported into Microsoft Outlook. The tool also provides preview, duplicate email removal, incremental export, and selective export features, helping maintain organized and clean PST data throughout the conversion process.
    276
    CubexSoft MBOX to PST Converter is an advanced solution designed to convert MBOX files into PST files with ease. It helps users export emails, attachments, contacts, calendars, and other mailbox data while preserving important email properties and folder organization. Whether you are migrating from Thunderbird, Apple Mail, Eudora, or another MBOX-supported email client, the software provides a straightforward way to manage and convert mailbox data. Its user-friendly interface makes the conversion process simple for both technical and non-technical users.
    Oct 2021
    52
    Looking for a professional tool to export MBOX to PST format with similar folder structure then try MailsDaddy MBOX to PST Converter tool This single application is enough to move single or multiple MBOX file to Outlook PST format without any technical hassle. The application manages internal and external folder structure during the whole conversion process. It keeps all mail formatting, header, inline images, attachments etc. during the whole conversion process. User can also use the free demo first and move few emails from each folder.
