Results 1 to 10 of 10
    Feb 2009
    1,686
    Looking for VPS Suitable for Hosting Game Servers
    Need high clock-speed vCPUs (Ryzen or latest Intel). Specs: minimum 3 vCPU, 6 GB RAM, NVMe storage.
    Low-latency network + strong DDoS protection required. Will it be worth using Hostingsource.com vps hosting service? Alternatives?
    Prefer providers with Canadian or European locations.
    Jun 2025
    272
    You could also look at InterServer’s VPS plans. Their 4 vCPU / 16 GB RAM / 320 GB SSD option is around $19.20/month with the JV-20-LIFE coupon, and their US locations could be worth considering if the latency works for you. For your requirements, I’d specifically confirm the CPU model, NVMe performance and DDoS coverage before choosing.
    Registered User NimbusRise's Avatar
    Aug 2024
    77
    If you’re looking for a VPS, I’d also check out HostPro. Their VPS servers run on KVM virtualization and NVMe drives, and they have several locations - Warsaw, Amsterdam, and Tampa - so you can choose a server closer to your target audience. Another plus is daily backups stored for 30 days. Plus, if necessary, you can restore not only the entire server but also a specific database, folder, or file. Technical support is available 24/7, which is also quite important for a VPS, especially if a problem arises outside of business hours.
    Registered User FireVM's Avatar
    Sep 2026
    19
    I think, attractive offers are not the only factor you should depend while selecting a host. You should check the reliability and the quality of service also.
    Read customer hosting reviews before making any final order.
    126
    Another VPS provider I came across is HostPro. They have servers in Warsaw, Amsterdam, and Tampa, running on KVM virtualization with NVMe storage. What I find useful is the backup setup: daily backups are retained for 30 days, and you can restore individual files or databases instead of restoring the whole server. Their technical support is available around the clock.
    Aug 2009
    843
    Trustworthy VPS deals are available from operavps.com and inet.ws.
    Exceptional services at fair prices. I rarely need help from the support team. Yet when I do, they are fast and fix the issue in a few hours.
    Dec 2025
    37
    When speed and quality both matter, the supporting services often make the difference. I've been with hostpro.com, and their daily backups of all services have allowed me to restore data after failed updates, damage, or hacking scenarios. Their technical support is qualified and available 24/7, helping with any question free of charge.
    Oct 2026
    7
    Which game, player count and mod/plugin setup are you targeting? Those details matter more than the advertised vCPU count alone. Ask whether the CPU allocation is shared or dedicated and whether sustained usage has a fair-use limit. A short test with your actual server build will tell you more than the processor's maximum clock speed.
    For the location, request a test IP in the exact Canadian or European facility and measure latency, jitter and packet loss from your players' networks during busy hours. For DDoS protection, confirm that the game's UDP/TCP ports are covered, whether filtering adds latency, and when the provider would null-route an attacked address. These questions should make the offers easier to compare before committing to a long billing period.
    Senior Member Glow's Avatar
    Dec 2008
    1,718
    The best support team I’ve ever worked with. Secure, reliable, and packed with great features — perfect for any website!
    The hosting environment feels professional. Grab Hostingsource.com VPS hosting for as low as $3 for the first month using code: $3VPSM1ALL
    107
    Navigating the crowded market of virtual private servers requires careful attention to performance and reliability metrics. From my extensive hands-on experience, the VPS infrastructure at hostpro.com consistently delivers the speed and stability I need. They automatically create daily backups of all services, ensuring you can quickly restore data in case of hacking, failed updates, or accidental data damage. Additionally, their excellent technical support team is available 24/7 to provide qualified, free assistance for any issue you might encounter.
