Results 1 to 6 of 6
    Oct 2026
    Hosting for a PrestaShop store?
    I'm launching a small store on PrestaShop and need shared hosting. Is hostpro.com a solid pick for this CMS? I'd need daily backups and DDoS protection.
    Mar 2009
    1,680
    Do you require any specific control panel like cPanel or DirectAdmin? Also, where do you want the server hosted?
    Pretty good website hosting solutions you can get from:
    1) Hostpresto.com
    2) Ayksolutions.com
    3) Hosting.com
    Worth every penny for the performance I get.
    Incredible performance with fast-loading pages — I’m truly impressed!
    Jan 2020
    265
    For this kind of Reddit/forum reply, I’d keep it casual and mention Fresh Roasted Hosting as another option without making it sound like an advertisement. Since it’s a small PrestaShop store, focus on PHP compatibility, database support, backups, and DDoS protection rather than buying an oversized plan.
    Feb 2009
    1,679
    Taking into account your needs, believe Centoserver.com cPanel web hosting solutions will serve your demands. Uptime and stability I can trust.
    The hosting is well-optimized for e-commerce platforms, making online selling effortless. Their SSL certificates provide added security for transactions and customer data.
    Apr 2026
    For a small PrestaShop store I would check the PHP version supported by your PrestaShop release (and that you can switch it), a memory_limit of at least 256 to 512 MB, OPcache enabled, MySQL or MariaDB, free SSL, and cron support for the PrestaShop tasks. Ask whether daily backups are stored away from the server and whether you can restore them yourself, and test one restore in the first week. Network-level DDoS protection matters more for a store than a big plan, so start small and upgrade when traffic grows. If you expect growth, check that moving to a VPS later is possible without rebuilding the store.
    Sep 2006
    988
    Right accounts are available from planethoster.com and scalahosting.com.
    Great reliability, the support is good, sustainability, the uptime is high, the speed is great.
