Results 1 to 5 of 5
    May 2008
    1,682
    Dedicated Server Needed for E-Commerce and Database Hosting
    I require a dedicated server suitable for e-commerce and database workloads.
    Specifications should include 64 GB RAM, 2 × 2 TB NVMe or SSD in RAID, and 15 TB bandwidth on a 1 Gbps connection.
    Strong network stability and hardware reliability are essential. Can you tell me about GTHost.com instant servers? Are they good?
    Budget is approximately $150–$180 per month.
    Aug 2009
    843
    Well-balanced servers are available from hostingsource.com and operavps.com.
    Tech support has always been a wonderful mix of professionalism and approachability. And their pricing has been extremely kind to me throughout.
    Jul 2008
    1,703
    Seamless upgrades with no downtime. Its long history in this business gives the reasons to treat it as the host with highly redundant servers and quality support. Unlike other dedicated instant servers, GTHost.com servers come with unmetered bandwidth which means you'll never be hit with unexpected fees when you have higher than normal volumes of traffic. Low-cost trial starting at $5/day - a good solution to test their servers. Good luck!
    Do you want to gamble? Here is ==>> ONLINE POKER
    Nov 2026
    It is very important to choose a reliable e-commerce site and database application. With dedicated hosting, you will have your own resources, full control, high speed, and a flexible setup. When choosing your dedicated server, make sure you select one with the right amount of RAM, SSD storage, bandwidth, backup and security features, and support.
    Registered User Virterion's Avatar
    Oct 2026
    8
    Customer support is one of the most important things to consider. A hosting company that responds quickly and solves technical problems efficiently can make a big difference.
