When an employee leaves a company or a department is restructured, IT administrators often need to preserve mailbox data before making changes to the user's Microsoft 365 license. The challenge is deciding how to retain important business correspondence, attachments, and historical records without keeping every account active indefinitely.
Before removing a license, administrators should identify which mailbox data must be retained and confirm the applicable retention policies. Depending on the organization's Microsoft 365 subscription and configuration, options may include retention policies, inactive mailboxes, or exporting mailbox data for a separate archive. These approaches serve different purposes, so the right choice depends on legal requirements, internal policies, and how frequently the archived information must be accessed.
For organizations that need a portable offline copy, exporting the mailbox to PST can be useful. PST files can be stored in an approved archive location and opened with compatible Outlook applications. However, administrators should plan storage capacity, access permissions, encryption, backup procedures, and retention periods before exporting sensitive business records.
The export process should also account for shared mailboxes, online archives, and public folders where applicable. Simply exporting a user's primary mailbox may not capture every location containing relevant information. A documented checklist helps administrators identify the correct source mailboxes and verify the resulting files.
The SysInfo Office 365 Export to PST Tool is one option for this workflow. It supports exporting Microsoft 365 mailbox data to PST and other formats, processing multiple mailboxes, filtering data by date, removing duplicates, and splitting large PST output files. Its preview and reporting features can help administrators review the selected mailbox content and export results.
For a reliable archive, validate the exported files before changing account access or removing licenses. Check representative messages, attachments, folder structures, and the output reports. Keep the archive in a controlled location and ensure authorized staff can retrieve it when needed.
One important distinction: a PST export should not automatically replace an organization's Microsoft 365 retention or eDiscovery strategy. Businesses with regulatory or litigation requirements should confirm that their chosen process meets those obligations before decommissioning an account.
