I am working with several PST archives that were created at different times for the same department. Some contain older project discussions, while others were exported during employee mailbox changes. I need to locate specific email records across these files, but opening each archive separately in Outlook and checking its contents is becoming difficult to manage.
My main requirement is to inspect the mailbox data before deciding which archive contains the information I need. It would help to browse the folder hierarchy, review message subjects, and compare sender names and dates across different PST files. This is particularly useful when filenames do not clearly indicate the mailbox period or the project associated with the archive.
I also want to avoid modifying the original PST files during the review process. These archives are retained for reference, so maintaining the source files separately is important. A viewing utility that allows independent inspection could make this task more manageable without requiring every archive to be imported into an Outlook profile.
I found the SysInfo PST Viewer while researching standalone PST viewing options. For IT teams handling multiple historical archives, what is the best way to compare mailbox contents efficiently? Are there any recommended checks for identifying the correct PST file before extracting or migrating its data.
