Choosing the right software developer involves more than checking their knowledge of programming languages. For a business application hosted on a dedicated server, it's important to consider both development skills and an understanding of deployment and infrastructure.
Here are a few things worth evaluating:
- Technical expertise: Look for experience with relevant technologies such as PHP, Python, Java, .NET, Node.js, or other frameworks that match your project requirements.
- Database knowledge: Developers should understand database design, query optimization, backups, and data security.
- Server-side experience: Knowledge of Linux environments, APIs, server configuration, deployment, and application performance can make a significant difference.
- Security practices: Check whether the developer follows secure coding practices, handles authentication properly, and understands common application vulnerabilities.
- Maintenance and scalability: Software needs ongoing updates, bug fixes, and improvements. Make sure the developer can support the application after launch.
- Regarding individual developers versus dedicated teams, the right choice depends on project complexity, budget, timeline, and the amount of ongoing support required.
If you are exploring different development hiring options, this resource about hire software developer may also help you understand different engagement models and developer requirements.
Ultimately, focus on practical experience, communication, code quality, and long-term project support rather than choosing solely based on cost.
