Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
    Mar 2016
    132
    What is Benefits Of VPS Hosting..?
    Hello friends,
    Sofia, Bulgaria
    128
    Vps hosting is generally cheaper than dedicated, its suitable to begin some small scale projects and if needed later can scale it further.
    Nov 2013
    Goa, India
    80
    Virtual Private Server(vps) acts like a dedicated server ,it is a cheaper solution as the cost of hardware is shared and hence its advisable for medium size businesses.
    May 2016
    122
    As with all types of web hosting, there are pros and cons to each and each one is suited to specific circumstances. Generally there are many advantages to hosting your site on a virtual private server. These include: A VPS hosting account is less expensive than a full dedicated hosting plan that uses a physical server.
    Jul 2014
    227
    Benefits of VPS server hosting are:
    More stability and reliability for basic web hosting needs
    More control compared to shared hosting
    Green technology, environmentally friendly, and more efficient
    Cost effective solutions for small websites
    May 2016
    Tulsa, OK
    20
    Quote Originally Posted by manvijoshi View Post
    Hello friends,
    Picture a VPS like a dedicated server. But, instead of having the entire server for yourself you share a portion but with root access. This allows you to have best server resources and mange the server to fit your needs.
    Hostwinds - Unlimited Web Hosting
    Cpanel/WHM | Not Oversold | Low Server Loads
    Hostwinds - VPS Hosting
    OpenVZ | SolusVM
    Skype Me! hostwinds.jessej
    Jul 2015
    84
    VPS Benefits
    * Virtual Private Server (VPS) SEO friendly,
    * Will get Dedicated IP,
    * More stability and reliability.
    * Secured then Shared Hosting,
    * Client will get more access on His VPS Server,
    * Compare to Dedicated Server will get VPS in low-cost.
    Inetwebhost.net : New Website Design
    Shared hosting at 1.99Euros/mo. | SSD Dedicated servers
    Affordable Unmanaged VPS | Cloud VPS | Metal Server and much more
    Nov 2015
    285
    Google can answer you better.. you can get some good articles or knowledge base on this. Are you looking for any VPS or you just need proper answer?
    Leasedlayer - Next-Gen Web Hosting services
    Get Special Web Hosting Deals on SSD Shared Hosting | Managed XEN VPS | Unmanaged OpenVZ and XEN Linux VPS | SSD Cloud VPS | Super Fast Dedicated Servers
    Jan 2013
    88
    VPS is nothing but the abstraction of “Virtual Private Server”. From the name itself, it is clear that VPS is not private server but virtually it acts like a private server.We can install any software or OS without affecting other virtual machines on the same server. With this technology of partitioning a single server, customer can enjoy the benefits which are similar to dedicated hosting.I have availed the Virtual Dedicated Server Hosting from 9cubehosting.com and have no regrets.My website's performance is detached from the other sites hosted on the same server.Hence my website is always up with their multiple servers around the world.
    Registered User webhostus's Avatar
    Feb 2011
    US
    74
    In simple words get root access like dedicated server and dedicated resources at cheap rate ,thats what VPS Server is all about.
    May 2016
    28
    The 5 Major Benefits of Using a Virtual Private Server:
    1. More stability and reliability for basic web hosting needs
    2. More control compared to shared hosting
    3. Green technology, environmentally friendly, and more efficient use of resources
    4. Easy scalability when needed
    5. Cost effective solutions for small websites
    Delhi NCR, India
    30
    A virtual private server (VPS) is a virtual machine sold as a service by an Internet hosting service. A VPS runs its own copy of an operating system, and customers have superuser-level access to that operating system instance, so they can install almost any software that runs on that operating System.
    854
    Advantages Of VPS Hosting :
    Complete Isolation: The VPS packages and there applications will remain unaffected disregarding of what another users do on his server
    Root Access: This allows the customer to install any other application of their choice
    Guaranteed Resources: The allocated CPU, RAM, HDD and bandwidth in your package will always be available for your applications.
    Multiple Choice of OS: You have the options of choosing either a Windows or Linux VPS hosting. But before choosing a VPS hosting provider, it is advisable to learn which type of VPS environment you will need to run your applications: Windows or Linux.
    24/7 Technical Support and Service Monitoring: Your VPS hosting package comes with a 27/4 technical support and service monitoring 365 days a year. You will also be provided with a money back guarantee depending on your chosen hosting provider. This comes as a standard - a reliable provider should meet your organization's needs through customer service.
    Along with this they also provides additional features such as :
    High Speed: Provides fast speed.
    Low cost: With features you need to think about the cost also.
    Better CPU performance
    Firewall Protection
    SSD Storage with RAID enable
    Free Upgrade anytime
    Mar 2018
    Delhi
    284
    More stability for basic web hosting needs
    Reliability for basic web hosting needs
    High Speed
    Low cost
    More control than shared hosting
    Cost-effective
    44
    Benefits of VPS hosting:
    1. Reliability
    2. Performance
    3. Root access
    4. Scaling of hosting resources without downtime
    5. Freedom to choose VPS operating system
